67 Users Online (66 Members):
Forums >> Revit Building >> Technical Support >> Tricky Formula Question
I am creating a Detail Component that is a circle repeated along a line, with parametric spacing. For example, if I draw a 4' line, with 1/2" spacing, the circles run the full length at 1/2" intervals. If I change the spacing to 3", I still want them to run the full length, but the overall number to diminish so that they are now spread out across the same 4' line, but at 3" intervals.
I have almost got this working using circles grouped to detail lines, and then an array. It is ALMOST great, but I can't figure out the right formula for the number of circles so that they always draw the maximum number of circles that will fit in the length that I draw. If, for example, I do (Length - Spacing) / Spacing + 1 then the number will round down and not always draw an extra one even though there is space. If I do (Length / Spacing) + 1 then it will sometimes draw an extra hole BEYOND the length I have drawn.
If this makes any sense, what formula would I use?
Thanks.
I've run into the same problem, and it seems to come from Revit rounding integer parameters. I have a family that arrays table legs, and checks to see if Revit is rounding down when it's not supposed to (or rather when I don't want it to). I have attached the family along with a .txt file that explains how the parameters work.
I suggest you send the file you already started in order to study the case
I sat down and thought for a while about it and tried (length / spacing) + .5, and that worked perfectly. Thanks for your suggestions.
basic formula question regarding parameter use |
Wed, Jun 16, 2010 at 5:34:23 PM
Tricky? Roof |
Mon, Sep 24, 2018 at 2:12:05 PM
Using schedule total in formula? |
Fri, Apr 4, 2014 at 10:29:50 AM
One family parameter has formula one has none |
Wed, Jun 25, 2014 at 1:05:54 PM
Parameter Formula |
Fri, Mar 5, 2010 at 12:09:09 PM
Members: | 2017185 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
