23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Pick and Turn Off Items from Linked Revit Model
Wed, Aug 1, 2012 at 11:23:06 AM | Pick and Turn Off Items from Linked Revit Model
leothelionator
When referencing a DWG file, there is a "Query" option that allows you to pick and turn off items in the linked file.  Is there anything similar when referencing a linked Revit RVT file?
Yes, I know I can go to Visibility Overrides and pick off categories one by one, but this is extremely tedious guesswork.  I"d rather be able to identify the culprit by picking it, then turning it off.
Wed, Aug 1, 2012 at 11:38:41 AM | Pick and Turn Off Items from Linked Revit Model
TKennedy
4 Stars: 7 Votes
Use the Tab key to highlight the element you want to select, then pick it. You can then right-click on it and hide either the element or category. Hiding the category is the same as going to V/G and unchecking the category, so be careful with that option.
Wed, Aug 1, 2012 at 1:15:03 PM | Pick and Turn Off Items from Linked Revit Model
leothelionator
Thanks!  I always forget about that useful tab key.
Cannot turn off levels in linked file
Mon, Jul 22, 2013 at 8:21:14 AM
Unable to PICK lines from linked file
Thu, Aug 21, 2014 at 8:47:06 AM
turn on/off worksets in a linked model
Fri, Sep 8, 2017 at 3:39:16 PM
Linked model reference lines showing
Fri, Feb 10, 2012 at 9:28:59 AM
Can't select model items by clicking
Wed, Sep 30, 2009 at 12:52:50 PM
Page generation time: 2.7056
