72 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Tagging equipment nested in casework family
Wed, Aug 1, 2012 at 10:00:13 AM | Tagging equipment nested in casework family
ArchiGirl08
Hello,
I am trying to tag equipment that has been nested into casework family. When I load the family into the project, the tag appears to be only for millwork. Is there are any ways to tag equipment built within the family?
Thank you very much!
Wed, Aug 1, 2012 at 10:39:27 AM | Tagging equipment nested in casework family
Revit recognizes that some elements are 1 item - like a window.  You don't need, or want to see, anything else that makes up the window.   But sometimes you have elements that have seperate parts like you have.  Revis default is a family is one element and only that information is available.
If you want a sub-family to be shared to the project, then you have to set that switch.  Edit the family and under the properties tab / family categories and parameters (yellow folder) / family parameters / set the shared switch.
Wed, Aug 1, 2012 at 2:09:16 PM | Tagging equipment nested in casework family
ArchiGirl08
I have made the casework family with nested elements shared and load back into the project. I am still unable to tag the equipment. Please see attached.
If you know any ways of how I can work it out, that would be GREATLY apprecisted!
Wed, Aug 1, 2012 at 3:22:28 PM | Tagging equipment nested in casework family
Works just fine.  Remember - these items are specialty equipment - not casework!
Wed, Aug 1, 2012 at 3:23:57 PM | Tagging equipment nested in casework family
ArchiGirl08
sorry... Yes. They  appear in the schedule but I would like to have a physical tag on the plan
Wed, Aug 1, 2012 at 3:29:20 PM | Tagging equipment nested in casework family
^^^ READ ^^^^ They are specialty equipment!  You have to use the correct tag.
Wed, Aug 1, 2012 at 3:32:56 PM | Tagging equipment nested in casework family
ArchiGirl08
Thank you for being so nice Smile
Void cut in nested casework family
Tue, Oct 15, 2013 at 12:46:49 PM
Locking nested families?
Wed, Aug 27, 2008 at 12:23:09 PM
13
Annotations nested inside a wall hosted equip family: Cant see the annotation
Wed, Aug 20, 2008 at 6:37:31 PM
Tagging Nested Families
Wed, Apr 8, 2015 at 3:13:34 PM
how to have text on a nested family show when its in the family it is nested to
Fri, Jun 5, 2009 at 3:30:32 PM
Page generation time: 1.1361
