128 Users Online (127 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> SPLIT FLOOR PLANS
Sat, Jan 7, 2006 at 1:40:28 PM | SPLIT FLOOR PLANS
arquia
2.5 Stars: 9 Votes
I NEED SPLIT MY FLOOR PLANS TO PUT DIFERENT MATERIALS I WANT TO DO THAT WITHOUT CREATE A 2 DIFERENTS FLOORS
Sat, Jan 7, 2006 at 5:19:54 PM | RE: SPLIT FLOOR PLANS
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use the split face tool, then paint a different material to the desired section.
Sun, Jun 1, 2008 at 10:15:52 PM | SPLIT FLOOR PLANS
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
I see how the split tool work.
In my case I have a large floor slab that I need to split.  Problem is that I have a heap of walls throughout and I need to cut/split in aisles etc....  I figured that you wouldnt need to split the slab from one edge to the other - I though there would be some intelligance on the floor where the split tool picks up the intersection of the walls/slab.  Othersie Im forces to trace the boundary off all my internal walls........
Split face on floor?
Wed, Nov 18, 2015 at 1:16:28 PM
Levels in Split Home Plans
Mon, Jun 12, 2006 at 7:48:39 PM
split region model patterns not showing up in all views??
Mon, Apr 10, 2006 at 2:09:19 PM
Enlarge Floor Plans
Thu, Feb 12, 2009 at 4:12:21 PM
12
Best Software to Create Presentation Floor Plans
Fri, Apr 30, 2010 at 12:56:47 AM
Page generation time: 1.4829
