Forums >> Revit Building >> Technical Support >> Revit Detail Level fill pattern, Texts in Elevation and Section's Symbols
41 Posts No Rating |
Hello there!
Can someone show me how to change the Cut Fill Pattern of Detail Level Coarse from Black to Gray? Per Category or per Type. Please not per element, because I don't want to have to select each one of my floors to change its coarse cut fill pattern, besides I know how to do that per element. I will like all my floor types to display a gray fill pattern when I choose the Detail Level Coarse. How do I do that? That's my first Question. I have tried doing that already but I noticed it also affects the Detail Medium Level; I want it to affect only the coarse Detail Level.
The other question is How do I include text on all those Section Symbol and elevation symbols? I have not figure out that yet.
Many thanks in advance.
I gues you mean this:
Go to the properties of the floortype & choose the desired fill pattern under Coarse Scale Fill Pattern & Color
about the section symbol:
select the section and click the arrows wich appear @ the end of the section line multiple times until the tekst appears
(this works with the default section symbols)
Thanks Gebber for your answer. I was able to change the coarse fill pattern easily. But about the section and elevation symbols, I mean on plans. I have no problems doing them in elevations and sections. But on plans I will like to show the sections and elevations numbers within the symbols. How do I do that?
I mean the texts within the callous of elevations and sections
See Image. How do I show texts in this Section Tags?
The text will automatically populate once you place the referenced view on a sheet.
TEXTS in Section and Elevation TAGS |
Mon, Jul 30, 2012 at 8:46:14 AM
Revit 9.1 Detail compontent fill pattern orientation |
Tue, Jan 14, 2014 at 4:18:31 PM
brick fill pattern - detail component |
Wed, Mar 19, 2008 at 10:38:41 AM
Fill Pattern Visibility Oddity |
Thu, Apr 19, 2007 at 9:42:28 AM
How to fill area with symbols/blocks? |
Mon, Nov 7, 2005 at 9:32:44 AM
Members: | 2098005 | Objects: | 23164 | Forum Posts: | 152289 | Job Listings: | 3 |
