118 Users Online (112 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Edit .rfa as an in-place family? 2012 Architecture
Fri, Jul 27, 2012 at 7:47:32 AM | Edit .rfa as an in-place family? 2012 Architecture
suzyblue222
Is there a way to convert or edit an .rfa family in-place? I am working on a complex floor pattern that needs to be edited due to some wall partition changes. For some reason it was created in-place using extrusions then exported as a family (by someone else). I tried to copy paste but find that Revit does not allow this. Any suggestions? Thanks.
Fri, Jul 27, 2012 at 7:54:02 AM | Edit .rfa as an in-place family? 2012 Architecture
You can't export an in-place family!
...and you can't change an in-place family to a regular family.rfa.  (You can always edit in-place families)
...and you can't change a loaded family into an in-place family.  Why would you ever want to do this?
Regrettably, you can copy paste an in-place family to other locations but this is not a good process.
I think we need more information in order to help you.
Fri, Jul 27, 2012 at 8:06:44 AM | Edit .rfa as an in-place family? 2012 Architecture
suzyblue222
Sorry...used the wrong teminology. It was apparently copy & pasted from an in-place family to an .rfa by a newbie in our office. Not sure what the reasoning was for it. Guess I'll just have to work around it. Thanks.
Fri, Jul 27, 2012 at 8:30:36 AM | Edit .rfa as an in-place family? 2012 Architecture
I don't think he did that either.  You can not copy from project to family or vice-versa unless that has changed in 2013.
Fri, Jul 27, 2012 at 1:01:39 PM | Edit .rfa as an in-place family? 2012 Architecture
TKennedy
4 Stars: 7 Votes
If you are editing the in-place family, you can C&P the elements (extrusions, symbolic lines, etc.) from the in-place family to a normal family. I just tested it, and it works in the other direction as well. So, no, you can't go from a project to a family, but you can go from an in-place family to a family, and vise versa.
Systems Furniture RFA Issues
Sun, Aug 21, 2016 at 2:01:35 AM
REVIT MEP 2012 WIRING - EDIT WIRE FAMILY
Wed, Jan 4, 2012 at 6:07:46 AM
Revit Architecture 2012 Library?
Sat, Sep 1, 2012 at 11:21:02 AM
Import full Civil 3D 2012 model in Revit Architecture 2012
Thu, Jan 26, 2012 at 6:23:36 AM
revit architecture 2012 installation
Fri, Sep 23, 2011 at 4:39:26 PM
Page generation time: 1.2843
