73 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> making the 2011 cover facade?
Thu, Jul 26, 2012 at 6:02:31 PM | making the 2011 cover facade?
agosztyla
For a job the client want a cut steel ribbon around the project similar to whats on the front cover of the 2011 cd case cove. question is what would be the best way to create something like this that wont slow down the revit file.
Fri, Jul 27, 2012 at 7:31:49 AM | making the 2011 cover facade?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"cut steel ribbon around the project"  Is this something that you want to show on your titleblock on every sheet?
Fri, Jul 27, 2012 at 7:47:58 AM | making the 2011 cover facade?
Use a material that has the holes defined in it.  Don't model the holes!
Wed, Aug 1, 2012 at 1:48:54 AM | making the 2011 cover facade?
agosztyla
With the material with holes i can get it to show how i want in render. But how do i get the holes to show on elevations and just in shaded
Wed, Aug 1, 2012 at 3:35:33 AM | making the 2011 cover facade?
4 Stars: 203 Votes
You need to apply a "pattern" in that wall surface BUT because that facade is a "little" complicated I believe you'll need to create those holes, check this guy (Zach Kron): http://buildz.blogspot.pt/
Random slidding panels on a curved facade ?
Tue, Mar 1, 2011 at 9:56:46 PM
Cover Sheet Components
Wed, Aug 31, 2005 at 9:30:04 AM
how can we make the curvy facade in revit 2013?
Thu, Dec 26, 2013 at 8:45:12 AM
Translucent polycarbonate facade
Wed, Apr 2, 2014 at 4:06:08 PM
metal facade?
Wed, Dec 21, 2005 at 9:37:11 AM
Page generation time: 2.0267
