60 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Windows not cutting through walls
Thu, Jul 26, 2012 at 3:43:32 PM | Windows not cutting through walls
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
not sure why but my wondows will not cut through my walls,  in plan and section look correct, but in elevation the do not show.
thanks in advance for your help
Thu, Jul 26, 2012 at 3:55:02 PM | Windows not cutting through walls
Did you use the normal wall cut in your window familyor did you do some special cuts using voids?
Do you have a thin wall applied to the face of your wall?
Edited on: Thu, Jul 26, 2012 at 3:55:23 PM
Thu, Jul 26, 2012 at 4:13:49 PM | Windows not cutting through walls
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
they are the same windows i have always used, i even tried the out of box windows with revit to test and they do the same thing. o thin walls just a 1'2" thick brick exterior wall.  Crazy thing the windows work fine on my 4 7/8" interior walls.
Thu, Jul 26, 2012 at 4:19:05 PM | Windows not cutting through walls
This problem is not unusual for thick walls.
If these are regular wall cut windows, then edit the family and change the host wall thickness to approximate what you have.  << this problem should not happen - it is a programming problem.
If these windows have multiple void cuts then that is more of a problem.  The main window cut void is not deep enough and needs to be changed.
Fri, Jul 27, 2012 at 8:09:06 AM | Windows not cutting through walls
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
hub,
Beginners mistake. after i got in this morning and started looking at his project. i quickly came to realize he was using existing walls and placing new windows in them and the view was not set correctly.  i did not realize last night he haad been using phasing.  after that all wass well. whixch would explain with the interior walls worked since they were new walls and new windows.
well, thanks for your help and i will remember your tip about opening cuts.
thanks again
Wed, Mar 9, 2016 at 5:44:19 AM | Windows not cutting through walls
BangalowJoe
I just made the same beginners mistake. Thanks goodness for old posts!
Sun, Nov 20, 2016 at 5:58:51 PM | Windows not cutting through walls
kjames427
Hey - still a beginner here and I think I made the same mistake you mentioned above.
I had an existing wall with one of my windows and I added three more. The original window is showing but not the three others. How do I change the view settings to see all for? Exactly which setting is it?
Mon, Nov 21, 2016 at 9:37:41 AM | Windows not cutting through walls
Under the view properties - phases - show all.
Can't figure it out, Windows are not cutting my walls
Fri, Apr 30, 2010 at 12:39:16 PM
Windows in leaning walls
Thu, Aug 11, 2011 at 9:49:46 PM
window not cutting joined roof
Mon, Mar 6, 2017 at 4:23:50 PM
Can only square panels in curtain walls be converted to windows?
Wed, May 16, 2012 at 2:22:01 PM
Window not cutting furred wall
Tue, Feb 14, 2012 at 12:56:04 PM
Page generation time: 3.5542
