65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> revit terrain and roads
Tue, Jul 24, 2012 at 2:46:06 AM | revit terrain and roads
cemcem
Hello;
I've modeled a terrain in Revit. The terrain should have existing roads on it and I am also required to do the roads in 3D. I'm not allowed to use sub-regions or that kind of projections on my terrain. If I take a section from some place on the terrain I have to see the roads as object being cut as layered objects.
Can any one suggest me a modeling strategy?
As far as I can think of here is what I'm planning to do: Using sloped pads between certain spot elevations of the road and dividing the road as much as possible into little pieces. but I also have to do the same process for pavements. And I don't know what kind of joining problems I will have at the end.
Beyond that I don't want to pay some extension called siteworks for revit, because that thing had to be made first by autodesk.
Thanks in advance.
Tue, Jul 24, 2012 at 7:14:13 AM | revit terrain and roads
I don't understand why you need to see layered objects in sections when this can easily be added as detail work.   We never model sloping/curved roads.  If you must do this then you should get the civil site works add on.  Otherwise, chack out this thread and pay attention to mbsteve's post.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=27738
Tue, Jul 24, 2012 at 4:29:18 PM | revit terrain and roads
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Attached is a method to accomplish this there is also a software add on available which does this rather easily or at least it appears to, SiteWork by EaglePoint.
Tue, Jul 24, 2012 at 4:35:28 PM | revit terrain and roads
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Also check this thread.  I started making an adaptive component road that has a very smooth top surface.  it won't help you model intersections, but it looks great as single long road segments.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=27733
Wed, Jul 25, 2012 at 2:19:58 AM | revit terrain and roads
cemcem
Great. Thanks all for replying so quick.
WWHub: I agree with you about detail work, but I am a worker not the bossSmile They want it this way.
I have read this document before, this might work but it is not so much practical.
And the oscar goes to itsmyalterego, I liked your solution. So close to eaglepoint siteworks.
How to create roads on terrain?
Thu, Sep 27, 2018 at 11:30:56 AM
Roads in a slope
Fri, Jan 13, 2012 at 1:47:52 PM
Where are the roads?
Thu, Jul 17, 2008 at 2:13:40 PM
Roads
Mon, Apr 3, 2006 at 10:21:48 AM
How to make Roads in site?
Mon, May 31, 2010 at 4:29:42 AM
Page generation time: 3.9329
