Forums >> Workflow & Implementation >> API & Third Party Apps >> is there/can there be a Halftone macro?
18 Posts No Rating |
Hi guys, I have no knowledge of macros nor programming habilities. That said. I find my self usign the "Overwrite by element/halftone" a lot for all sorts of elements. I was wondering if someone has/knows how could I make a macro/shortcut in order to speed up the process...thanks
13 Posts No Rating |
Hi,
would you say these elements are in the same catagory? i.e. Chairs & Tables, typically Furniture?
If that is the case you could create a view template with that catagory set to halftone?
Alternatively you could use a trans material on those elements?
Just throwing it out there before you resort to code, 4th.
hey 4th I use that when ever i can (although not on a template, but will try it out), but its not always the case, most of the times I only need to halftone a few elements on any given category...thnanks
Perhaps those elements should be in a different workset and use Template VG settings to 1/2 tone that workset of view filters.
you can set up a shortcut for Halftone by Element in the Keyboard shortcuts dialog.
Macro request |
Mon, Jul 19, 2010 at 10:35:01 AM
Design Options Halftone? |
Tue, Nov 20, 2018 at 10:58:57 PM
Revit MEP 2012 - Halftone not Working... |
Fri, Oct 5, 2012 at 12:47:22 PM
halftone hatch/fill pattern? |
Wed, Jan 16, 2008 at 10:14:13 AM
Forcing a drafting opening /closing view with Macro |
Thu, Dec 8, 2011 at 2:37:23 AM
Members: | 2098609 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
