Forums >> Revit Building >> Technical Support >> error opening revit projects in revit 2013
5 Posts No Rating |
Okay here is the situation , recently downloaded revit architecture 2013 , installed it , properly licenced , everything working , but there is some kind of bug where whenever i try to open a file by double clicking it , the revit program starts , give me the "one time upgrade" message for my file (upgrading from revit 2012) , then closes , to successfully open my files i have to open revit 2013 first then select open --> my project file......
please any help would be much appreciated.
We prefer to have our staff always open the proper revit version before opening a file. This helps to prevent the staff from opening a file in a later version when we really don't want them to. There is no reduction in speed doing it this way.
I have seen the problem you state in earlier versions of Revit. I have not seen anyone offer a solution.
Edited on: Tue, Jul 24, 2012 at 8:51:47 AM
5 Posts No Rating |
thankyou for the fast reply , i always work in the latest version so i hoped to solve this problem because it would be mush easier for me
![coreed Avatar](user_avatar/14568.jpg)
i never heard of this one for Revit. please don't for get to post when you find a resolution. i stopped double clicking to open large data driven programs also due the posibility sometimes of unknown effects. i have seen it with other programs.
5 Posts No Rating |
sure i will , i hope to find a solution
I think we are saying the solution is Don't do that!
5 Posts No Rating |
well its not easy to let go of bad old habits u know , but i will try to , by the way , no news about vray supportin revit? , if this happened i can ditch max
5 Posts No Rating |
yeah i figured out as much , but the idea is that i am trying to solve a bug in the program , not deciding whether to use this method or not , i simply asked for a bug fix , thankyou all anyway , i appreciate the quickness of answering boring questions like mine.
"auto" open in Revit 2012, when you have both 2012 and 2013 |
Sun, Jul 12, 2015 at 4:52:17 PM
Revit 2013: not enough memory to open project |
Tue, Jun 12, 2012 at 1:41:26 AM
Translating Revit 7 projects (And Office-particular) Library families into Revit |
Tue, Jul 19, 2005 at 12:00:00 PM
Revit 2013 Toposurface Tool Error |
Sat, Dec 8, 2012 at 8:47:24 AM
13
Placing an opening through a wall 'island' |
Wed, Jun 5, 2013 at 4:35:42 PM
Members: | 2022356 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
