63 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> tiling seamlessly
19 Posts No Rating |
I want to tile images while rendering in Revit seamlessly. I have photos of material and I want to apply them to objects like couches and have them tile seamlessly.
It's very difficult to get a material to tile seamlessly. You have to do the 'MC Escher trick' of having the edges on one side interlock with the edges of the other.
http://www.turbosquid.com/Search/Artists/Revitaoist |
Sometimes you need to do some editing of an image to do this. You can't have a sharp trnasition edge to edge in either direction. If your image is shaded like that, look for a better, more uniform image if you can. Sometimes you have to have a bigger sample. A 10'x 10' image rater than a 2' x 2' ... or similar.
This is your problem to correct, the Revit software will not do it for you.
Adjust hatching to follow brick courses or tiling for tiling layouts |
Tue, Aug 5, 2008 at 10:14:12 AM
Tiling Layout |
Wed, Oct 6, 2004 at 1:28:49 AM
Placing filled regions for tiling in bathrooms |
Fri, Jun 10, 2005 at 10:35:11 AM
Tiling windows |
Thu, Jan 30, 2014 at 2:20:42 PM
Tiling Seamless Texture Images |
Tue, Oct 12, 2004 at 8:08:15 PM
Members: | 2030502 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
