79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Stacked wall core boundary
Thu, Jul 19, 2012 at 4:46:28 PM | Stacked wall core boundary
fastjohnnyz
I have a created a stacked wall. Precast conc (highlighted in blue see jpeg), on top of that a stud wall w/ met. panels (these are 2 separate walls w/ the studs & met. panels ontop of the precast). Its in place in my model. I forgot I needed to furr out the inside of my precast conc wall w/ 6" met. stud and gwb (see jpeg). So when I do it, it actually moves the whole wall and re-centers it there by makin my bldg larger. How do I just add the 6" met. furring (see jpeg) right behind the precast w/o moving the precast conc wall whatsoever? Any suggestions
Fri, Jul 20, 2012 at 6:56:42 AM | Stacked wall core boundary
You call this a stacked wall, is it or not?  If it is a stacked wall, then the offset is defined in the stacked wall definition.
For Offset, select the plane that will be used to align the subwalls. (This value is used for the Location Line instance property for each subwall.)
Stacked Wall Core
Thu, Jan 7, 2010 at 12:55:27 PM
Stacked Walls - how to set wall core
Mon, Apr 20, 2015 at 7:33:53 AM
Walls extend to core boundary
Fri, Mar 17, 2006 at 8:16:47 AM
Dimension Stacked Walls
Thu, Aug 18, 2011 at 12:23:36 PM
wall types, core boundries + dimensions
Tue, Feb 28, 2006 at 4:29:56 AM
Page generation time: 2.2136
