43 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> line weight question
Wed, Jul 18, 2012 at 1:57:20 PM | line weight question
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
Do most people use the thin medium and wide lines for your project or do you make your own lines with varying weights different from the out of the box.  I have always wanted to know but never thought to ask. I have always made my own but it seems to be a little tiresom these days. i have different line weights set up for each scale factor and when setting view vis it gets old scrolling through my list. again just wondering if it is possible to maintain the out of the box and have your views look like there is enough line weight control to make your view look good.
Wed, Jul 18, 2012 at 2:07:36 PM | line weight question
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I have 6 or so lineweights that I use.  They're scaled so that they print at an appropriate weight regardless of the view and the scale.
In my Linetypes, I preface the line name with the weight of the line.  IE:  1_thin, 2_med_thin, 3_med, 4_med_heavy, 5_heavy, 6_very_heavy.
Keeps my line types logically organized at the top of the list so I know what I get.
Edited on: Wed, Jul 18, 2012 at 2:29:09 PM
Wed, Jul 18, 2012 at 2:57:05 PM | line weight question
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
I have similar setup to 'itsmyalterego'; I have 10 line types to choose from and I simply list them as 1-10 with the appropriate lineweight.
Wed, Jul 18, 2012 at 3:10:59 PM | line weight question
We are similar to its except we don't prefice the number.  We have not modified the scaling chart so our line weights are not sequential like its.
It took us a couple of years to modify our object style settings.
Wed, Jul 18, 2012 at 4:14:56 PM | line weight question
TKennedy
4 Stars: 7 Votes
I have named our line types according to their use, e.g. Indirect Drain, Direct Drain, Electrical Connections. That is for plan work, for standard details I'm still using the OOTB Thin, Medium, Wide. I really need to get that cleaned up at some point (probably right after I find this "free time" that keep hearing about), but it's working for now.
Fri, Jul 20, 2012 at 8:24:11 AM | line weight question
Ptrdckrsn
Ptrdckrsn Avatar
1 Stars: 1 Votes
Thanks for the advice, all very good and alot of food for thought. Sorry it took me so long to thank you all.
Line weight in family doesn't equal line weight in project
Fri, May 31, 2013 at 2:54:30 PM
Change Leader line weight
Tue, Apr 29, 2008 at 1:30:01 PM
Mon, May 21, 2007 at 6:01:05 PM
Line Weight as Family Parameter
Fri, Mar 16, 2007 at 4:23:59 PM
Making Line Weight a Parameter?
Mon, Mar 19, 2007 at 1:59:56 PM
Page generation time: 0.8259
