87 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2013 Material User Interface
Wed, Jul 18, 2012 at 10:39:32 AM | Revit 2013 Material User Interface
Mboyer
Where within the material editor is the Material Description that is tied to the Material tag?  This was readily available in previous versions, but not so much now.
Wed, Jul 18, 2012 at 1:13:49 PM | Revit 2013 Material User Interface
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I'm not quite sure what you mean.  I have attached a photo of the 3 dialog boxes that you should see when opening up the material editor.
Wed, Aug 22, 2012 at 12:53:18 PM | Revit 2013 Material User Interface
ADGORGONE
I'm having the same issue. There should be a description that will control the text in the Material Tag just like in 2012, but it doesn't seem to be there.
Wed, Aug 22, 2012 at 1:22:30 PM | Revit 2013 Material User Interface
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
It is in your material editor.  See the attached.
Edited on: Wed, Aug 22, 2012 at 1:23:08 PM
Wed, Aug 22, 2012 at 1:44:01 PM | Revit 2013 Material User Interface
The WIKI Help would have gotten you here too:
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/3032-Customiz3032/3042-Project_3042/3060-Material3060/3119-Changing3119
Thu, Sep 20, 2012 at 3:55:34 PM | Revit 2013 Material User Interface
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
Im curious as to why sometimes my texture editor looks different. My intention was to change the bump material, it came in at a large scale so I went into 'edit image' and was met by the image on the left. I tried to change the size by it would not let, it'd just reset back to 7'. I closed the editor windows down right back to my project, re-opened the editor and was met by the image on the right. No big deal, I'm just curious about the variation, anybody else see this?
Thu, May 2, 2013 at 4:50:54 PM | Revit 2013 Material User Interface
sroreilly
I've been encountering this & wondering the same thing.... Seems very odd.
Revit Architecture 09 - User Interface
Thu, May 29, 2008 at 3:27:13 PM
Setting User Interface
Tue, Aug 14, 2007 at 5:03:41 PM
Revit 2013 Material Creation
Fri, Mar 15, 2013 at 3:35:41 PM
User material folder when upgrading Revit
Fri, Apr 21, 2006 at 6:25:28 AM
Duplicate material still changes original in Revit Architecture 2013 [ 1 2 ]
Thu, Jan 21, 2016 at 12:03:11 PM
24
Page generation time: 2.1978
