Forums >> Revit Building >> Technical Support >> selection window grabs wrong items
I have a image drawing underlayed for an office plan tracing, and I want to use a selection window on a small column so I can move it, but when I try to draw a section window, it just grabs the jpeg underlay...How can I get Revit to ignore the image and just make selections in the plan view.
Try using a crossing and then your filter.
thats just it. the initial click to start a window just selects the scanned plan image first...cant even begin a selection window.
Image underlays are a serious pain in the curse. It's always the first selection. Whenever I work with an underlay, there's a lot of hiding/unhiding going on.
It'd work a lot better if an image could only be selected by the border.
or made to be "unselectable" in view whils still being visible..
Try putting the image on its own workset and move the image to Design Option 1. That's what we do with our links. This makes them unselectabe- you have to uncheck "exclude options" next to the design options drop-down on the bottom to select it. I'm not sure if that will work for an image file, but it's worth a try.
jlights |
polyline selection window |
Sat, Feb 6, 2016 at 7:57:08 AM
Stumped on why window selection or crossing selection wont pick pipe fittings ? |
Sat, Jun 1, 2024 at 1:44:17 PM
Selection Tool 2016 Multi-level Selections |
Mon, Jun 1, 2015 at 2:15:32 PM
selection issue |
Fri, Mar 4, 2005 at 3:43:12 PM
Revit 2014 Selection Window |
Fri, Apr 11, 2014 at 7:49:25 AM
Members: | 2100905 | Objects: | 23171 | Forum Posts: | 152292 | Job Listings: | 3 |
