153 Users Online (152 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Using Centerline dimenisons
Thu, Jan 5, 2006 at 3:31:50 PM | Using Centerline dimenisons
justinmthomas2003
I am currently using Revit 7. In there, it doesn't have centerline dimensions. A dimension which you start at an box's midpoint to next box's midmpoint. Anyone know how to do that? Thanks,
Thu, Jan 5, 2006 at 5:37:10 PM | RE: Using Centerline dimenisons
Scott Davis
3.5 Stars: 3 Votes
How did you draw the "box"? Was it a loaded family component? If so, edit the family and add ref planes defined as Center Left/Right and Center Front/Back. Save the family and reload it. Now the dimensiosn have a "center" reference to snap to, which will display with centerline options if you've set up your dimension properties to display that way.
Fri, Jan 6, 2006 at 9:22:33 AM | RE: Using Centerline dimenisons
justinmthomas2003
Oh thank you very much. It now makes sense. Thanks for you help. I apperciate it very much.
Centerline Symbol in Text [ 1 2 ]
Wed, Jun 30, 2010 at 8:29:06 PM
19
Roof centerline
Fri, Nov 7, 2008 at 1:53:57 PM
11
dimension to centerline of mullion
Wed, Nov 13, 2013 at 12:19:56 PM
Centerlines
Thu, Jul 14, 2011 at 10:43:25 AM
Dimensions w/ centerline symbol - Revit 2013
Mon, May 11, 2015 at 1:40:34 AM
Page generation time: 0.1792
