72 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Modify Topo & Building together
Fri, Jul 13, 2012 at 8:38:47 AM | Modify Topo & Building together
hfinn
Hi,
Does anyone know of a way to modify both Contour Lines (Topo) and the actual building in the same file?
i.e. without linking the file "topo" to the file "building"?
Many thanks,
H.
Fri, Jul 13, 2012 at 8:54:14 AM | Modify Topo & Building together
Topo lines in Revit are created from the points either imported or added.  They are not "drawn".  So to change them, you have to add/subtract points from the topography.
Not sure what this means > "...and the actual building in the same file."
Fri, Jul 13, 2012 at 8:59:21 AM | Modify Topo & Building together
hfinn
Hi WWHub,
Thanks for your answer.
I'm in Revit 2012 and I want, in the same file where I am designing my building, to be able to modify the contour lines.
Basically they told me: creat a file for your topography. Create another one for the building. Link the first to the second and, each time the first is modified, the changes will appear in the second. I want everything "together" in one file...is it at all possible?
Fri, Jul 13, 2012 at 9:14:10 AM | Modify Topo & Building together
Just do that.... I would rather have my site in a seperate file in most of our projects, but you don't have to.
Topo is struggling
Tue, Aug 15, 2006 at 9:24:02 AM
2009-Topo & Pad...anyone has an idea
Tue, Jun 30, 2009 at 11:33:26 PM
Topo surfaces,
Mon, May 12, 2008 at 4:33:53 PM
topo depth
Wed, Nov 7, 2012 at 2:17:32 PM
14
How do I modify building pad in Revit Structure 2012?
Mon, Aug 22, 2011 at 5:15:26 PM
Page generation time: 2.1653
