52 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> Shaft Problem
I am using Revit Architecture 2012. Here is my issue. Some time ago I made a shaft for an elevator opening. I decided today that I wanted to delete that shaft. Strangely, I can't highlight it in order to delete it. There are other ways it is behaving strangely as well. I can't highlight the shaft in any view. It is not hidden - I can't highlight it when I reveal hidden elements either.I got desperate enough that I made a 200 foot thick floor slab so that I could try and find the beginning and end of the shaft; it seems to go on endlessly, which is strange considering that there seems to not be any way to leave the bottom of a shaft unconstrained. Then, the third floor slab that exists in the model does not show this shaft cutting through it, yet when I made my super-thick floor it showed the shaft opening going well over the top of the building. What is this crazy thing and how can I get rid of it?
Are you sure you still have it? Edit your floor slab and see if there is a hole sketched where the slab is.
Could it be in a workset that is turned off?
Whew! I am so glad it was something so simple! It was hanging out in a workset where it didn't belong. I thought I had exausted all of the "obvious" stuff - thank you so much!
Is your problem that he's a bad mother-shut yo mouth!
I am so sorry, I just couldn't help myself.
Shaft!! |
Mon, Apr 13, 2015 at 8:51:04 AM
shaft cutting beams |
Tue, Jun 2, 2009 at 7:47:18 AM
A Floor That Can't Be Penetrated by Shaft Opening |
Thu, Feb 20, 2014 at 2:30:48 PM
Shaft Visibillity |
Wed, Jun 1, 2011 at 10:47:37 AM
Visual override of Shaft Opening |
Tue, Sep 6, 2011 at 4:44:32 AM
Members: | 2056329 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
