46 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Green roofs
Thu, Jul 12, 2012 at 9:31:50 AM | Green roofs
fastjohnnyz
I have a green roof on my 2nd flr with a patio and planters. What is the best way to fill in between w/ soil/earth? Do I create a slab and change materials? I tried doing a topo by picking the plane and changing the elevation, but that didn't work
Thu, Jul 12, 2012 at 9:51:55 AM | Green roofs
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
do you need to actually show a thickness of material in any sections?
If not, you could just use the paint tool and apply an earthy material to the top face of your slab.
Thu, Jul 12, 2012 at 10:06:48 AM | Green roofs
fastjohnnyz
If I have to, I could do as you say Absolute. But I would like to try within reason make the model as realistic as I can. In particular having a section cut thru it and showing the true thickness of the earth/soil. I did create a slab and change the material to site-earth. Works well but my slab is sloped for drainage so there's that triangle where nothing shows up. I could model a mass in that triangle space but it would suck up too much juice. I know eventually I probably will just do the easy route but was curious to know if there was a way to do what I am trying to do
Thu, Jul 12, 2012 at 10:10:47 AM | Green roofs
Why not just an in-place family with the earth material?
Thu, Jul 12, 2012 at 1:03:37 PM | Green roofs
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
You can also make it a slab, and show various layers of rock fabric, and soil as a variable thickness, and then you can slope the top to drains, etc.
Thu, Jul 12, 2012 at 4:59:43 PM | Green roofs
revitape
revitape Avatar
4.5 Stars: 9 Votes
i do what WW suggested... in place component. i usually put an instance material parameter on it so you don't have to edit in-place just to change materials. that's exacty what i did for the attached plaza image (for water and grass)
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture
Green Roofs
Tue, Jan 4, 2005 at 1:08:50 PM
How to make a Green Roof
Fri, Feb 1, 2013 at 11:28:35 AM
Pool Water Green in Rendering
Thu, Feb 16, 2012 at 1:17:14 PM
James Hardies Revit content walls are green?
Fri, Jul 10, 2015 at 5:17:01 PM
UNDERSTANDING space and space tags - Green coloring
Fri, Jan 27, 2012 at 11:25:14 AM
Page generation time: 1.5040
