108 Users Online (106 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Tips & Tricks >> INSTANT PARAMETER SCHEDULEABLE
Wed, Jul 11, 2012 at 11:23:17 AM | INSTANCE PARAMETER SCHEDULEABLE
sllana
5 Stars: 2 Votes
Hi, i'm trying to do a wall pass-throgh seal that I need in various sizes that I want to control as instance parameters and they work fine, but when I set those dimension parameters as "Reporting Parameter", they are no longer editable from the instance properties window. So....does anyone know how to do it? . . . . If possible
Edited on: Thu, Jul 12, 2012 at 8:23:06 AM
Wed, Jul 11, 2012 at 12:07:11 PM | INSTANT PARAMETER SCHEDULEABLE
Reporting parameters report!  From your HELP: "A reporting parameter is a parameter type that has its value driven by a particular dimension in the family model. Reporting parameters extract a value from a geometric condition and use it to report the data to a formula or as a schedulable parameter."  So as such, you can't set them.
  • Reporting parameters are useful when a family is driven by external references that are updated based on contextual information from placed family instances, such as curtain panels or the width of a wall for the frame of a door or a window.
  • For external reference cases in which the geometry depends on the specific conditions of individual family instance placement, the reporting parameter allows the dimension value to be saved and reported in the family parameter.
  • A reporting parameter can be used in a formula only if its dimension references are to host elements in the family (such as levels, curtain panel boundary reference planes). If any of the dimension's references is to family geometry, the dimension can be labeled with a reporting parameter, but this parameter cannot be used in formulas.
So why do you want this to be a reporting parameter when it already works as an instance parameter?
Wed, Jul 11, 2012 at 12:23:18 PM | INSTANT PARAMETER SCHEDULEABLE
I believe you were wanting a shared parameter which could be instance.  Again, from your HELP:
Shared parameters are particularly useful when you want to create a schedule that displays various family categories; without a shared parameter, you cannot do this. If you create a shared parameter and add it to the desired family categories, you can then create a schedule with these categories. This is called creating a multi-category schedule in Revit Architecture.
Wed, Jul 11, 2012 at 12:26:37 PM | INSTANT PARAMETER SCHEDULEABLE
sllana
5 Stars: 2 Votes
Because I want to put several instances of the object in cuestion, set the dimension of of each one without making several Types (but instance variation) and make a schedule that gives me a list of all of them with their respective sizes. Or what would be the way to do this.?
Wed, Jul 11, 2012 at 12:44:07 PM | INSTANT PARAMETER SCHEDULEABLE
You must have missed my last post and did not understand my first post.  NOT reporting - you need shared.
Wed, Jul 11, 2012 at 2:08:58 PM | INSTANT PARAMETER SCHEDULEABLE
sllana
5 Stars: 2 Votes
Thank you WWHub, now I got it. And I could do it. I was trying to understand that for months. Thank you again for your concern.
Edited on: Wed, Jul 11, 2012 at 2:14:04 PM
Edited on: Wed, Jul 11, 2012 at 2:15:22 PM
Family Instant Parameter Constraints Offset
Fri, Feb 1, 2013 at 2:41:01 PM
TYPE-INSTANT PARAMETER not permitted ANY WORK AROUND?
Sat, May 9, 2009 at 1:46:43 PM
Can I arrange parameter list?
Wed, Jan 7, 2009 at 10:09:50 AM
customize text parameter
Fri, Jan 26, 2007 at 10:12:33 AM
Door Data Global or Instant
Tue, Nov 29, 2005 at 12:25:47 PM
Page generation time: 0.4157
