35 Users Online (34 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Importing AutoCAD Layer standards
Tue, Jul 10, 2012 at 3:56:13 PM | Importing AutoCAD Layer standards
cody21
I'm trying to export my revit drawings to autocad and was wondering if there was a way to import specific autocad layers into revit so when they are opened in autocad the layers diplay correctly. I have found the dwg export settings and noticed there are only a few different layer standards and they are read as .txt files. To this point the only way I can think of doing it is by changing them all manually in Revit. Let me know if anyone can help
Thanks
Tue, Jul 10, 2012 at 4:00:16 PM | Importing AutoCAD Layer standards
DevonK
4 Stars: 5 Votes
Ive done some research on that and found out the only way to do it is manually in Revit. I havent heard of any other way.
Tue, Jul 10, 2012 at 5:26:10 PM | Importing AutoCAD Layer standards
TKennedy
4 Stars: 7 Votes
Start with one of the standards .txt files (I used the AIA file), edit it to suit your needs, then use it when you export. It can be a little confusing/tedious to set up, but once you have it right you should be good to go.
Wed, Jul 11, 2012 at 8:19:21 AM | Importing AutoCAD Layer standards
cody21
Ok thanks for the replies
Layer Settings of imported Autocad drawings
Tue, Jan 18, 2011 at 8:14:16 PM
AIA Standards- Revit to AutoCAD layers
Thu, Feb 1, 2007 at 12:50:29 PM
Tri-Servies Standards
Tue, Aug 28, 2007 at 12:06:16 PM
exporting to dwg - load layers from standards
Thu, Jul 16, 2015 at 5:24:59 PM
importing layer settings
Mon, Apr 11, 2016 at 10:09:20 AM
Page generation time: 0.6518
