Forums >> Community >> Newbies >> Permanently isolate object in Revit?
35 Posts No Rating |
Is there any way to permanently isolate objects in Revit?
I have many objects in my project that i am making fabrication drawings for and i am having problems of always having to go through the sheets to fix my drawings
I have tried to use assemblies but it is only helping to a certain extent.
Would be great if there was a option like temporary isolate that only was permanently isolate.
Isolate? Are you using the correct term?
Would groups be your answer?
I think i am using the correct term yeah
I would like if there was an option to isolate objects and it would work permanently not only temporarly like the "tempoaray isolate object" does
You mean only show that object in a view then.
There would be a couple of ways to do this. The best would be to put this object in a workset by itself, then create a view and turn off all worksets but this one.
Yes that is what i mean.
I dont have much experience working with worksets but i guess i have to check it out
Usually everything is in a single workset in my projects so i dont have to think about it.
How is normal working method for worksets?
Thanks for great responses as always.
How do i turn off workset in single view?
VG settings in that view.
