27 Users Online (25 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit Linked File Question: UNABLE to unhide linked contour in Site plan window
Sat, Jul 7, 2012 at 3:54:59 PM | Revit Linked File Question: UNABLE to unhide linked contour in Site plan window
psharma
main Project file : Site plan has a linked contour topography revit file .
My 'VG' column for Overlay/halftone in Site plan window is UNCHECKED.
But I am not able to see the contour lines at all. not even grey lines.
The countour is visible in the "hidden elements" window.
But after selecting the topo , when I click on "unhide elements " or "unhide category", THE TOPOGRAPHY LINES do not become viisble in view, in short, unhide does not work on this.
FYI: The linked countour is visible in all other windows, ie, sections, plans, elevations and views.
What should I do to solve it?
Mon, Jul 9, 2012 at 1:36:22 PM | Revit Linked File Question: UNABLE to unhide linked contour in Site plan window
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
try going back into your VG settings and go over a few tabs to Revit Links, your linked file should appear here. Verify the the display settings are set to "by host view". Also be sure to expand the link if the little plus sign appears, ensure that the little check box are marked.
Mon, Jul 9, 2012 at 2:31:35 PM | NEED HELP! Revit Linked File Question: UNABLE to unhide linked contour in Host
psharma
The problem is not yet solved!
I have attached a few screen shots to help explain the problem more.
I am stuck up with a submission over due!
I would be happy to share the file via mial/ dropbox (size @ 20 mb)
Tue, Jul 10, 2012 at 9:20:41 AM | Revit Linked File Question: UNABLE to unhide linked contour in Site plan window
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
as I mentioned in my previous post, try marking the check box for the link so it appears...see attached.
Tue, Jul 10, 2012 at 3:04:23 PM | Revit Linked File Question: UNABLE to unhide linked contour in Site plan window
psharma
I appreciate your suggestion.
I tried this right now.
It did not solve the issue. :-(
Tue, Jul 10, 2012 at 3:42:10 PM | Revit Linked File Question: UNABLE to unhide linked contour in Site plan window
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
did you try expanding the link? hit the little plus sign, there may some sub-items, make sure these are all checked ON.
Unable to PICK lines from linked file
Thu, Aug 21, 2014 at 8:47:07 AM
Linked Revit Models
Mon, Apr 2, 2012 at 7:36:05 AM
Help Needed: Unsolved Linked file Question
Mon, Jul 9, 2012 at 4:32:30 PM
Can the linked revit drawings preserved its phasing setting in master site plan?
Fri, Apr 4, 2008 at 8:58:30 PM
Modifying a linked revit site plan
Wed, Feb 28, 2007 at 9:40:41 AM
Page generation time: 2.5984
