82 Users Online (81 Members):
Forums >> Revit Building >> Technical Support >> Importing Revit Drawings
When trying to load a saved revit drawing into an open revit drawing I encountered a problem. The drawing seemed to go across but became invisible. I know this as when I tried to import the same drawing again I got the following message:
At least one instance of this link already exists. It could be invisible because the link is unloaded. Continuing will create a new instance for this link and reload it.
Can anyone explain what happened and how to successfully import the drawing
Thanks
Check your visibility settings under the Revit Links tab and make sure you have them checked.
importing autocad drawings |
Fri, Jan 15, 2010 at 10:27:49 AM
Importing ACAD Drawings - Experiences? |
Fri, Aug 6, 2004 at 8:54:57 PM
Importing from AutoCAD - distant origins |
Mon, Mar 17, 2008 at 6:00:27 AM
Importing .dwgs into Revit |
Mon, Feb 9, 2004 at 5:13:11 PM
Imported Drawings Visibility Issues |
Mon, Oct 8, 2007 at 4:08:24 PM
Members: | 2030550 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
