49 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Foundation lines showing up hidden
Thu, Jul 5, 2012 at 10:20:48 AM | Foundation lines showing up hidden
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I don't know if I am missing something in 2013 but I can NOT get my foundation lines to show up hidden.  I set the bottom cut plane to just above the footing and the view depth to just below and the lines are showing as solid.  Any ideas on what I am doing wrong?  I haven't had this problem before so maybe its just me messing something up today.
Thu, Jul 12, 2012 at 9:37:56 AM | Foundation lines showing up hidden
cbieser
1 Stars: 1 Votes
is your <beyond> linetype set to a hidden linestyle?  also double check your view ranges or try setting view depth to unlimited.
Thu, Jul 12, 2012 at 4:55:00 PM | Foundation lines showing up hidden
Manny
3.5 Stars: 6 Votes
YOU NEED TO HAVE A FLOOR/SLAB GOING OVER IT SO THE FOUNDATION LINES CAN GO FROM SOLID TO HIDDEN
Changing Linetypes in Foundation Plan
Thu, Mar 18, 2010 at 7:18:01 AM
Hidden Lines disappeared from all my Elevations
Fri, Mar 1, 2013 at 12:37:04 PM
HSS column hidden lines not showing up
Sat, May 7, 2011 at 4:34:57 PM
hidden lines below grade
Mon, Oct 1, 2007 at 2:19:41 PM
Elevation/Creating Hidden lines
Fri, Mar 12, 2010 at 12:43:17 PM
Page generation time: 0.6850
