82 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Grey out Truss
Thu, Jan 5, 2006 at 7:08:32 AM | Grey out Truss
bobbo
Hi I have removed the walls from a section view so I can draw framing details. Unfortunately I have a truss which has become visible through a wall that I''m detailing. As I want to print this sheet temporary hide for the truss will not work and I need to show all the other trusses. Is there some way I can grey out this truss - it actually would make the drawing easier to understand in combination with the framing before it. Hope this is not too confusing... Cheers
Thu, Jan 5, 2006 at 5:36:18 PM | RE: Grey out Truss
Merlin
Hi, I'm not quite sure what you're after exactly, but as a "quick fix", you might try to use the pen tool on that particular truss using invisble lines, a grey style line of your making, or whatever.....you can always come back later use the pen tool to change it back....as I said I'm not sure exactly what you're after. If you're after a better answer, re-post and give us another explanation of the situation John Mc
Thu, Jan 5, 2006 at 10:04:52 PM | RE: Grey out Truss
bobbo
Cool that did it Merlin - Thx Cheers
Truss overhang help
Wed, May 23, 2012 at 8:32:23 AM
About sphere truss..HELP!
Thu, May 3, 2012 at 12:56:26 PM
Truss - Rotating
Thu, Feb 6, 2014 at 9:10:40 AM
need help making delta truss system or space truss ???
Wed, Oct 29, 2008 at 12:17:38 PM
Tripod truss - diagonals
Mon, May 19, 2008 at 8:43:50 PM
13
Page generation time: 0.7219
