46 Users Online (45 Members):
Forums >> Revit Building >> Technical Support >> Create pie shaped roof, but no curve
6 Posts No Rating |
I need to create a pie-shaped roof. But when I create a "Roof by Footprint", and I use the arc part of the roof as my sloped edge, and the roof is set to slope at a 4/12 pitch, it creates the roof with the 4/12 pitch from the arc to the point, but thru the cross-section, it is an arc. How do you create this roof so it is flat, when you would view it thru the cross section.
Hope you understand what I am looking for.
Thanks
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
I don't think I totally understand.. you are makind a round roof? Can you attach a picture of what you are trying to accomplish? If you do not want the roof to slope and just want a flat roof click on the outline of the roof when you are editing and on your options bar there will be a check box that says "DEFINE SLOPE", UNCHECK that box.
6 Posts No Rating |
This is the "pie" that I am trying to create. It is hard to tell, but not only does it go up at a 4/12 pitch (to the peak), it also curves (you can tell by the shingle hatch).
Now I do realize, that in order to get it flat, the facia, or curved edge, will actually be concave (the middle part of the facia going down)
![alfmedina Avatar](user_avatar/41302.jpg)
![4 Stars: 8 Votes](/images/stars_4.gif) |
I don't understand the problem. If the plan is a quarter of a pie, and the slope is only at the curved edge, the section of
the roof shows straight lines, not arcs.
Edited on: Wed, Jul 4, 2012 at 10:59:25 AM
Planta1 Revit Online Consulting | info@planta1.com |
![3.5 Stars: 4 Votes](/images/stars_3.5.gif) |
can you put in a short straight section (say 50mm) in centre of curve, then apply slope to this straight section only.
this way the roof will be all 1 plane as you require.
cheers
Curved Stairs in a Pie Shaped configuration |
Tue, Mar 15, 2005 at 5:25:00 PM
saddle shaped roof on a gymnasium? |
Tue, Aug 7, 2007 at 2:52:03 PM
WAVE ROOF FAMILY & bracing |
Mon, Sep 17, 2012 at 4:36:29 AM
12
Trouble with the Curve (Roof that is) |
Tue, Aug 5, 2014 at 9:24:32 AM
To create an egg-shaped mass? |
Mon, Aug 27, 2012 at 5:16:05 PM
Members: | 2022380 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
