40 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> how to override values of level grids?
Mon, Jul 2, 2012 at 9:25:15 PM | how to override values of level grids?
barryco
like the one you can do in dimensions, you can text-override the dimension
how do i do this in level grids? the function seems missing. thanks
Tue, Jul 3, 2012 at 5:15:26 AM | how to override values of level grids?
4 Stars: 202 Votes
What do you mean with "override values of level grids" ?
Tue, Jul 3, 2012 at 7:49:30 AM | how to override values of level grids?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can't override a level, if you set a level at 100'-0" thats what it is at.
Thu, Jul 5, 2012 at 11:49:13 AM | how to override values of level grids?
SwiftImage
It can be done using shared parameters and creating a new level head annotation family and type.  We use it occationally when we need the elevation to read as "VARIES" rather than a specific value.
~SwiftImage
Thu, Jul 5, 2012 at 3:50:01 PM | how to override values of level grids?
FWelliot
Or you could move the enitre building/project by altering the coordinates and thereby the elevation height of each level.
Thu, Jul 5, 2012 at 3:54:00 PM | how to override values of level grids?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
It depends on what you re trying to do.  Faking a level height is NOT a good idea or good practice.  As SwiftImage stated, if you are trying to get a "VARIES" type not on there then you can use an annotation symbol which is not associated with your levels and will be view specific.
Aligning grids the same in each level?
Fri, Sep 23, 2005 at 11:13:40 PM
new user - copying grids to other levels
Mon, Dec 6, 2010 at 3:06:36 PM
Elevation Level Override
Thu, Apr 5, 2018 at 1:22:36 PM
Changing level height values while keeping building in place? [ 1 2 ]
Mon, Apr 13, 2015 at 1:47:49 AM
18
Applying changes in grid to all views
Wed, Dec 26, 2012 at 9:22:58 AM
Page generation time: 0.4899
