71 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> Flirting with 3D max
Wed, Jan 4, 2006 at 4:39:33 PM | Flirting with 3D max
algis01
Revit requires floors to be built to the edge of the building envelope, but this causes unsightly results in 3D Max. Any clues?
Thu, Jan 5, 2006 at 8:55:20 PM | RE: Flirting with 3D max
bowlr
Why are you using 3D Max, what about the rendering in Revit?
Thu, Jan 5, 2006 at 8:59:45 PM | RE: Flirting with 3D max
algis01
I'm a bit fan of mental ray and I like the camera features that Max provides, but I do agree that rendering in Revit is also a good way to go.
Sun, Jan 8, 2006 at 10:45:34 PM | RE: Flirting with 3D max
eldados
eldados Avatar
4.5 Stars: 8 Votes
depends on how you are going to construct the building. revit does not requires floors to be built to the edge. if you are using blockwork for your walls, you can have a clear wall face going all the way up and you won't see the floor, you can do the same with concrete walls. so... just finish your floors on the inside of the wall and take the wall up to the top of your slab... HTH
Integrator
KarelCAD
Tue, Mar 7, 2006 at 5:16:57 AM | RE: Flirting with 3D max
MikeChan
3 Stars: 5 Votes
1st thing I would like to point out is Revit not a rendering tool. No doubt, Revit is a smart programe and capable to produre drawings in short time. However, Revit is very weak in rendering, based on the time consumption and the outcome quality. If I was you, I would do the model in Revit and do the texture mapping in 3D max or Viz. Becuase the rendering quality and the rendering speed is faster than I do the rendering in Revit.
Revit FBX causes 3DS Max to crash
Wed, Aug 10, 2016 at 6:02:28 PM
render my walkthrough in 3DS MAX
Tue, Apr 23, 2013 at 2:07:41 PM
Revit bring into 3ds Max [ 1 2 ]
Sat, Dec 25, 2010 at 6:24:34 PM
17
Revit to 3d Max FBX [ 1 2 ]
Wed, Dec 1, 2010 at 8:52:14 PM
17
Revit 2009 to FBX Import into MAX 9?
Wed, Jan 21, 2009 at 1:12:23 PM
Page generation time: 0.2134
