Forums >> Revit Building >> Technical Support >> Revit Template Family Object Styles
Mon, Jul 2, 2012 at 9:55:11 AM | Revit Template Family Object Styles
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
I am trying to bring imported CAD details up to Revit standards and one of the steps is purging confusing or unused lineweights/linestyles. I am about to go through each family we have and rename the object styles to its pen weight, so that in our template, with a bunch of details loaded, we only have linetypes 00, 01, 02, 03, etc...(in addition to the standard ones that Revit won't let you delete, like <hidden>, Heavy, etc.)
Is there anything I should be aware/concerned of before I undertake this?
Mon, Jul 2, 2012 at 10:18:36 AM | Revit Template Family Object Styles
Yes... All of the families that are already built using the standard category line types.
I think that you will find the standard Heavy - Medium - Thin and the standard category linetypes named similarly, a much better (and easier) practice.  Of course you will want a couple more but don't do this like CAD.
Change Default Family Category Model Object Styles
Thu, Jun 18, 2009 at 4:23:45 PM
Updating a Projects Object Styles from a loaded Family
Tue, Feb 24, 2015 at 1:31:34 PM
Object Styles
Mon, Apr 5, 2021 at 9:39:38 AM
Object Styles: not implementing
Tue, Jun 1, 2010 at 11:50:13 AM
Object Styles-Can't find where to change cut lines on sweeps--------------------
Mon, Sep 29, 2008 at 4:54:03 PM
Page generation time: 4.4514
