58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> ROOM SCHEDULE VIA WORKSET
Fri, Jun 29, 2012 at 1:16:00 PM | ROOM SCHEDULE VIA WORKSET
yilin1985
I have 3 buildings on campus. Some of the rooms #s in building 1 duplicates room #s in building 2. I want to create a room schedule and organize it by building type.  I'm thinking filter by workset would be most suitable b/c each of the 3 buildings were created on their own workset.
However, I can't seem to filter by workset.  Is there a work around for this?
USING REVIT ARCHITECTURE 2013
Sun, Jul 1, 2012 at 9:40:16 PM | ROOM SCHEDULE VIA WORKSET
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
You need to enter the building number in the rooms, and then filter the schedule by that parameter.
For example, if the worksets are named such as "building 1", "building 2", etc, you could select all the doors of building 1 and copy the name of the workset to the Comments parameter. Do the same for the doors of the other building. Then, filter the schedule by Comments.
Edited on: Sun, Jul 1, 2012 at 9:40:52 PM
Edited on: Sun, Jul 1, 2012 at 9:41:18 PM
Planta1 Revit Online Consulting | info@planta1.com
Mon, Jul 2, 2012 at 7:59:43 AM | ROOM SCHEDULE VIA WORKSET
You don't need to use the comments field, that might be useful for your regular schedule.  Instead, add a project parameter for rooms and doors and whatever else that is called something like "BUILDING No.".  Then filter schedules appropriately by this parameter.
Mon, Jul 2, 2012 at 8:17:05 AM | ROOM SCHEDULE VIA WORKSET
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Yes, of course. If you plan to use the "Comments" field for something else, then create a parameter exclusively for
the building name.
Side note for the moderators: I am noticing, maybe one or two weeks ago, that the text box where one types a reply,
this one, does not create the automatic carriage return to the next line of text, instead I have to hit enter myself to go
to the next line of text. Otherwise the end of the sentence goes beyond the limit of the box, on the right, where I can't
see it. Any help on that?
Mon, Jul 2, 2012 at 8:27:46 AM | ROOM SCHEDULE VIA WORKSET
alf,
The problem must be your browser.  I use Mozilla and I have no problems - I don't have to add returns.  I would bet that if you type it all on one line, it will display correctly here.
What browser are you using?
Mon, Jul 2, 2012 at 8:41:06 AM | ROOM SCHEDULE VIA WORKSET
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Thanks. My browser is Firefox 13.0
Mon, Jul 2, 2012 at 8:43:22 AM | ROOM SCHEDULE VIA WORKSET
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Yes, if I type all in one line, it will display correctly after I have submitted the post. But when I am typing, like...........now,
the rest of what I am typing goes beyond the right edge of the window, so I have to hit enter to force the carriage return..
again...
Schedule concrete volume (including column, slab & beam) by workset
Thu, Oct 28, 2010 at 8:04:52 AM
Find a specific room in the room schedule
Thu, Jul 4, 2019 at 2:08:03 AM
Embedded window schedule in Room schedule
Thu, Nov 19, 2015 at 1:03:49 AM
Workset Visibility Issues In Linked File
Wed, May 7, 2008 at 2:19:36 PM
automating door schedule ( From room # To Room #)
Thu, Jun 20, 2019 at 2:14:07 PM
Page generation time: 0.4687
