108 Users Online (105 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Import SAT file w/ material & section cut
Thu, Jun 28, 2012 at 10:12:44 PM | Import SAT file w/ material & section cut
KRAMERER
I've imported .sat files from rhino and have not found a way to have them both a) section cuttable and b) material renderable
when I import the sat as a family (casework) I can see it in section, but cannot apply material to it
when I import it simply as an object I can apply material to it through imported objects tab in manage.
I would like to have my cake and eat it too.
Help.
Fri, Jun 29, 2012 at 5:05:13 AM | Import SAT file w/ material & section cut
4 Stars: 202 Votes
" a) section cuttable" ---> It all depends if the family is Cuttable or not-cuttable.
"b) material renderable" ---> In Rhino apply some colors/material to that obj. then in Revit you can select them and change like you want.
Look at the bottom of this page: "Similar threads".
Fri, Jun 29, 2012 at 9:45:01 AM | Import SAT file w/ material & section cut
KRAMERER
Right, I can easily do those things individually, but the problem arises when I need both. When I import the .sats to a cuttable family (ex: casework) it won't let me add a material parameter to it. When I import the sats directly to my project, I can give them a material but can't section them...
Fri, Jun 29, 2012 at 10:03:25 AM | Import SAT file w/ material & section cut
4 Stars: 202 Votes
I don't have Rhino or any rhino file with materials to check... post one with one or two material(s)...
Import SAT file
Fri, Nov 30, 2012 at 9:42:19 AM
Importing SAT files
Fri, Jan 18, 2008 at 3:15:28 PM
2010 Conceptual Massing and .sat files
Fri, May 27, 2011 at 12:46:18 PM
.dwg, .sat file import problems
Mon, Mar 13, 2006 at 2:59:50 AM
sat file viewing problem
Fri, Jun 19, 2015 at 7:38:53 AM
Page generation time: 16.1071
