48 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Revit MEP HVAC Lag?
Thu, Jun 28, 2012 at 12:28:05 PM | Revit MEP HVAC Lag?
Alexassyia
 am working on creating a HVAC system for an office building and everytime I edit anything about the system (add duct, add fitting, delete something, change length) it takes at least 10 to 30 seconds per command. The computer has plenty of memory as it is only using 6 out of 15 GB. I think it may be caused by revit running calculations each time I edit something because if I draw a new piece of duct not connect to the main large HVAC system there is no lag for that segment but as soon as I connect it to the large system the lag is back. Is there a way to turn off the calculations that revit is doing?
Other details-
I have separated segments of the system on worksets and have turned them off when not using them but this does not fix the problem.
When I do anything with the system Revit says regenerating in the bottom left corner with a loading bar.
Your help would be greatly appreciated
Thanks
Wed, Jul 4, 2012 at 10:58:46 AM | Revit MEP HVAC Lag?
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
can you post details about your system?
maybe even refer to your systems 'Windows Experience Index' similar to the attachment. Sp;ecifically the Gaming Graphics category.
This is for my work system and everything works fine, my home PC has an inferior graphics card and operates similar to what you're describing.
can revit create hvac fabrication drawings???? help!!!! revit MEP 2009
Fri, May 7, 2010 at 12:00:48 AM
MEP-Slow Piping-Huge Lag time
Tue, Jan 4, 2011 at 4:54:14 PM
thermostat in hvac system R-MEP-2009
Wed, Jan 21, 2009 at 5:02:53 PM
viewing structural, architectural & hvac in 3d with shading and edges
Tue, Apr 20, 2010 at 5:53:58 AM
HVAC Ventilation Outside Air
Tue, Jan 8, 2013 at 10:15:50 AM
Page generation time: 2.4772
