78 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Large Format Rendering
Wed, Jun 27, 2012 at 11:38:26 AM | Large Format Rendering
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I have to produce an 8'-0" wide [2438mm for you Aussie's) rendering at 300 DPI for a billboard and I am struggling. PC keeps running out of memory. (16gb)
Any tips on how to produce a large format rendering like this ??
Tried rendering to Screen and Printer?
Wed, Jun 27, 2012 at 12:05:33 PM | Large Format Rendering
What about splitting it up in sections using the render region?
Wed, Jun 27, 2012 at 12:16:46 PM | Large Format Rendering
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Thx . . . interesting suggestion. As long as I can accurately locate the splice points and sew them back together.
I called a printing house and they said they can blow it up from a smaller image and retain a decent resolution as long as the original was 300 DPI. I think I'll try that next.
Wed, Jun 27, 2012 at 5:27:57 PM | Large Format Rendering
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
My machine also has 16 gigs, and I have never run out of memory on a render... although I've never tried for 300dpi over 96 inches.  I would suggest toning down your render quality to no higher than high ( I like medium) and render at 600dpi and a smaller actual size.  (this doesn't make logical sense, but I'd do it anyway)  10000px blown up to 8 ft is still more resolution than a computer monitor, at 108dpi opposed to 96.
So 300dpi on a billboard is just outrageous, in my opinion.  300 dpi is the resolution you need for an inkjet photo you hold up to your nose.  150 dpi would totally suffice, even if people got 3 ft away from it in a board room.
Aim for 15,000px width, and I think you'll be satisfied with the final product.
Wed, Jun 27, 2012 at 6:30:53 PM | Large Format Rendering
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
if you are using windows 7 64bit you could also try plugging in any thumb drives you have and turn on the "readyboost" function. you can add a couple hundred gigs of memory this way but I am not sure how exactly readyboost and mental ray work together.
Thu, Jun 28, 2012 at 10:15:55 AM | dgcad
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting dgcad from 2012-06-27 12:16:45
You should be able to do this type of blow-up work yourself also in photoshop.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Oct 22, 2009 at 8:44:35 AM
Keynoting and the new 2004 CSI Format
Thu, Sep 24, 2009 at 3:05:30 PM
13
How Large Can A Rendering Be Blown Up?
Fri, Jan 15, 2010 at 2:10:27 PM
Rendering a LARGE image
Mon, Nov 23, 2015 at 7:50:19 AM
Importing and rendering a model in DWG format [ 1 2 3 ]
Sun, Aug 30, 2009 at 1:56:50 PM
31
Page generation time: 1.5678
