112 Users Online (110 Members):
Forums >> Revit Building >> Technical Support >> Site Elevation to Floor Level Problem
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
Maybe I am missing something really simple but I just can NOT figure this out! I have a floor level at 1688', I start drawing my toposurface which is at 1683' (for the first few points). when I go into an elevation I would expect to see the toposurface 5 feet below the floor level but instead it is 95' above the floor level. Now in our template we have our default floor level set up at 100' so is there something in a setup that is forcing the toposurface to offset 100' above the floor level?
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
This is a tricky one to field in text over a discussion group.
It has to do with the 'elevation base' type property of the levels themselves [project or shared] and whether the project was relocated or not.
Edited on: Wed, Jun 27, 2012 at 11:32:04 AM
Thanks! Our level type properties was set to survey point instead of Project Base point!
Spot Elevation vs. Level elevation |
Wed, Feb 14, 2018 at 6:13:20 PM
Elevation Level Marker Associated To Wrong Floor Plan |
Wed, Feb 25, 2015 at 10:44:23 AM
Problem w display of floor patterns over diff. levels |
Sat, Mar 19, 2005 at 2:05:24 AM
Level Markers with both a project elevation and survey elevation |
Tue, Jun 21, 2011 at 4:09:56 PM
site rendering |
Thu, Oct 12, 2006 at 3:46:28 PM
Members: | 2017084 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
