Forums >> Community >> Newbies >> Deleting an element within 3D environment doesn't delete the element from the 2D
17 Posts No Rating |
Deleting an element within 3D environment doesn't delete the element from the 2D environment why? I am finding as a newbie i am making tones of mistakes and pressing "E" the "space bar" to delete say a wall in my 3D model space. Why doesnt that very same wall get removed/ deleted in the 2D space. Do i have to have both windows Tabb'ed side by side for this to work?
You are absolutly incorrect. When a model element is deleted anywhere, it is deleted everywhere - period!
2D Elements are view specific. Not sure what you are doing or what your shortcuts may be. I usually just select the object and hit the delete key.
do you maybe have a 2D AutoCAD plan link in that was used to trace over top? maybe that is what your seeing.
aHH! Your are indeed correct! I was using the Delete for just that space! cheers. I have just changed my UI so delete is now E also.
2D elements, linework, annotations, tags and dimensions are 'view specific'. You would need to delete in all views even though you can copy and paste them from view to view. They are not associated with their originator.
3D Elements will be deleted in all views. Thngs like walls, floors, stairs, roofs, pipes, ducts, furniture, toilets, casework, railings. . . . etc.
If you do not want to see a 3d element in a specific view you can hide the element or hide the entire category.
Keep a positive attitude. . . . you'll get there.
View Specific! thats brilliant. thank you.
Can't delete infilling element without deleting its insert or host. |
Tue, Sep 8, 2009 at 3:29:45 PM
can't delete sweep |
Wed, Jun 25, 2008 at 3:25:04 PM
Assigning a scope box to a section leads forces me to the delete the section. |
Mon, Jan 11, 2016 at 10:10:53 PM
Family Element ID's |
Thu, Jul 2, 2009 at 11:19:17 AM
switching element type to curtain element error |
Wed, Nov 16, 2011 at 1:37:03 PM
Members: | 2122514 | Objects: | 23210 | Forum Posts: | 152313 | Job Listings: | 3 |
