48 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> finish edit mode tab issue
Tue, Jun 26, 2012 at 10:29:11 AM | finish edit mode tab issue
coske
Hey fellas Smile
have a lil issue that it seems, there is no answer to...
the 'finish edit mode' tab goes missing.
say i make a roof, on occasions it will give me the green tick (finish command)...if i need to edit the footprint, somtimes it will give me an option to edit the footprint...but when i want to finish editing, the options is not there...so i have to go through 4 ribbon configurations, to get the finish mode option.
its preety much similar issue to finidh/edit groups but im having those options go missing on edit wall profile, edit roof, edit floor...
im on revit 2012 and using windows 8 on 64bit dell i7 xps lptop.
revit 2010 was a dream to work on, but recent upgrade to 12 is really giving me headaches...any help would me more than appriciated.
Wed, Jun 27, 2012 at 1:25:33 AM | finish edit mode tab issue
coske
noone...???
i did assign the keyboard shortcuts though
Wed, Jun 27, 2012 at 6:38:28 AM | finish edit mode tab issue
4 Stars: 204 Votes
Did you have installed the latest Web-update for 2012? I believe they solved this issue long time ago... Look at the "Download" section on this link: http://usa.autodesk.com/adsk/servlet/ps?siteID=123112&id=2956546&linkID=9243099
Thu, Mar 20, 2014 at 7:47:39 PM | finish edit mode tab issue
BigDor
Except this way, do you have another? Sometimes the edit mode tab is there, sometime he's not there...
Help!
Also, does it have a exit shortcut on the keyboard?
Fri, Mar 21, 2014 at 7:02:27 AM | finish edit mode tab issue
3.5 Stars: 401 Votes
You don't say what Revit and what updates you have installed.   We can't help you.
Fri, Mar 21, 2014 at 9:48:41 AM | finish edit mode tab issue
BigDor
I have Revit Architecture 2012.
I dont know which update i have. Were can i find it?
Fri, Mar 21, 2014 at 9:56:20 AM | finish edit mode tab issue
Look here:
If you have installed 2014, that messes up a dll used in 2012 and that has to be replaced.
Fri, Mar 21, 2014 at 10:23:43 AM | finish edit mode tab issue
BigDor
No, i dont have 2014 installed.
I stay with my 2012 version.
Everything work good except since 3 weeks. The edit tab missing sometimes...
Fri, Mar 21, 2014 at 10:43:38 AM | finish edit mode tab issue
You don't show us that you installed your updates..... Please don't post again unless you show us that.
Thu, Aug 9, 2018 at 10:50:48 PM | finish edit mode tab issue
Madina13171
WWHub your answers are very rude and not polite.
Fri, Aug 10, 2018 at 6:29:40 AM | finish edit mode tab issue
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Try amending the Revit settings in the Windows Registry. This solution seems to work on our office computers.https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Revit-Ribbon-disappears-after-opening-project.html
Stairs Disappear upon edit sketch mode.
Wed, Jun 6, 2018 at 12:49:18 PM
group edit mode
Mon, May 27, 2013 at 8:32:56 AM
Buttons on taps not coming up for needed commands
Tue, Mar 4, 2014 at 9:05:17 AM
Unable to end commands/exit edit mode
Wed, Aug 14, 2013 at 7:08:11 AM
Revit won't (Grey/Halftone/Fade) during any Sketch/Edit/Modify mode
Tue, Feb 27, 2018 at 11:18:53 AM
Page generation time: 2.5201
