46 Users Online (45 Members):
Forums >> Revit Building >> Technical Support >> Discipline showing to light
I have a mechanical plan which is set to the Mechanical Discipline and the architectural elements (walls etc) are showing up light which is good but they are showing up a little bit to light. I can change the discipline to Coordinate and that makes all of the lines the same darkness which isn't what I want. Is there a way to change the architectural/other disciplines to show up just a bit darker when the mechanical discipline is being used?
I attached a photo of my settings and plan.
Not sure but isn't this your halftone settings? Manage tab/additional settings - halftone & underlays
Thats it thanks!
"Discipline" settings effecting two models differently |
Mon, Aug 17, 2015 at 1:19:25 PM
Controlling Display setting per Discipline |
Fri, Feb 17, 2012 at 12:33:04 PM
Lighting fixture not showing ANY light |
Fri, Apr 10, 2009 at 12:30:55 PM
Sub Discipline under Views? |
Fri, Apr 17, 2009 at 2:21:21 PM
Linked walls not showing up |
Thu, Sep 20, 2012 at 11:13:20 AM
Members: | 2022586 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
