65 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> Revit Identity Data export to Navis
7 Posts No Rating |
Hello All,
I have been tasked with the following...
"The following data/attributes are required to be present in the native CAD file (i.e. dwg, rvt) and as visible CAD properties in Navisworks:
Object ID (Mark ((assumed to be from Identity Data))"
Line Size (Diameter)
Line Material Type
Facility Type
I have been able to provide all but the "Mark" data thus far. The 'Family Properties' data exports just fine but I cannot get the objects 'Mark' data to be visible in Navisworks.
Basically Client wants to see the objects 'Tag' in Navis. All parts in the production plant have tags that maintenance will use to identify the items.
How do I get the Properties/Identity Data/Mark information from Revit 2013 to be visible in Naviswork 2013?
7 Posts No Rating |
Please disregard my query as I have found the solution I needed.
Hi, not sure if you will see this but how did you figure it out, also having the same problem.
Thanks
Please can you provide feedback on the solution.
3D DWF export in Revit 2009 does not export identity data |
Thu, Nov 19, 2009 at 12:01:43 PM
Identity Data |
Thu, Oct 6, 2005 at 10:21:03 PM
IFC export/import and "Identity Data" |
Tue, Nov 5, 2013 at 6:04:10 PM
Editing existing Identity Data in a Family |
Tue, Sep 22, 2009 at 12:34:42 PM
Navis Export to Revit |
Wed, Mar 21, 2018 at 6:18:07 AM
Members: | 2030502 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
