Forums >> Revit Building >> Technical Support >> Cut Fascia by roof
3 Posts No Rating |
How do I cut a roof fascia (and gutter and soffit) by an intersecting roof? At the moment the fascia board runs the length of the building and I want it to be cut by the new intersecting wing. I have attached an image.
Create an "Opening Dormer" in the main roof then apply the fascia and gutter, then stretch those blue dots to the position you want.
Or you can use an "In-Place" family in Roof category and create a VOID to cut that gutter and fascia....
Edited on: Mon, Jun 25, 2012 at 5:46:32 AM
3 Posts No Rating |
Thanks for both methods. I went for the easier of the two which was the first one- make opening and then drag the blue handles on the fascia. It works well but does leave a bit sticking through the roof (as in attached image) so at some point I will get my head round the second method which I guess allows you to cut the fascia at the same angle as the roof.
As per Ty, I would create and in-place void and use 'cut geometry' to remove that excess material.
3 Posts No Rating |
I'll make a note to cut geometry. Also, DG of Cad Clips, I've learnt a lot from watching some of your video tutorials. Really useful. Thanks!
Roof Fascia On Negative Sloped Roof |
Wed, May 15, 2013 at 9:47:36 AM
RAC09 - Roof Fascia Corner Miter on Square Cut |
Wed, May 27, 2009 at 6:57:01 PM
Gable End Fascia |
Wed, May 23, 2007 at 5:45:51 AM
Fascia Board Too Long |
Tue, Nov 20, 2012 at 10:19:32 AM
ARCHED ROOF FASCIA |
Fri, Apr 21, 2006 at 3:33:18 PM
Members: | 2115637 | Objects: | 23192 | Forum Posts: | 152303 | Job Listings: | 3 |
