50 Users Online (48 Members):
Forums >> Revit Building >> Technical Support >> Getting rid of shadows in Revit rendering?
2 Posts No Rating |
I'm an MEP guy so this is stumping me. I am trying to help someone out by doing a rendering of some rooms.
Is there any way to render so that there are no shadows?
I have it set up so the walls are transparent and all my colors set, but when I do render the sun is casting shadows. Is there any way to do a rendering without shadows and have it full of light still?
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
In Render setting you can control the Sun and Shadows.
2 Posts No Rating |
I still can't get it to not cast shadows. I'm not sure what I'm doing wrong.
I don't believe that you will be able to completely turn them off but look up "soft shadows" in your help menu
![itsmyalterego Avatar](user_avatar/109615.jpg)
I am genuinely curious -- If you are not interested in shadows, then why are you doing a rendering?
If you want the render materials only, then I would suggest the "Realistic" view style. With or without edges.
![4 Stars: 5 Votes](/images/stars_4.gif) |
try turning off sun and shadows in the 3d view before you go to Render window. otherwise, the post above is the answer.
YES!! you have to adjust sun settings.before rendering ,in sun settings-lighting-set azimuth and altitude as 90 ![](https://forums.autodesk.com/t5/image/serverpage/image-id/434016iAB869B8096022DF6/image-size/large?v=1.0&px=-1)
Revit shadows in rendering |
Thu, Jan 14, 2010 at 12:14:48 PM
Rendering problem with soft shadows on Revit Arch 2010 |
Wed, Jan 20, 2010 at 5:58:33 PM
Moving shadows in animations |
Thu, May 5, 2011 at 5:42:26 PM
rendering no shadows |
Fri, Aug 31, 2007 at 2:21:06 AM
Elevation rendering - roof shadows |
Wed, Jun 16, 2004 at 1:13:00 PM
Members: | 2022237 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
