103 Users Online (101 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Wall type with recessed wd panels
Wed, Jun 20, 2012 at 11:15:32 PM | Wall type with recessed wd panels
mayo905
Looking for wall type that have wd base, recessed wall panels, chair rails and crown molding; at least any idea in how to add the recessed panel sweep or profile into the wall type, anybody?
Thu, Jun 21, 2012 at 12:27:30 AM | Wall type with recessed wd panels
agosztyla
Could you create a new wall by using the edit family, I know that theres a stacked wall that you might be able to use as a base. or maybe if you didnt have to add it to many walls you could modle a void or alike for what you need
Thu, Jun 21, 2012 at 7:34:32 AM | Wall type with recessed wd panels
You can not create this as a wall type.  I would use in-place sweeps for the chair-rail and base.  I don't like these defined in the wall type but they can be.  I would use an adjustable face based void family to create the recessed panels.  You can then paint the voided areas or if their is a layer at the depth of the void, that material can be revealed.
RECESSED PANELS IN EXTERIOR WALLS
Mon, Oct 31, 2005 at 4:22:38 PM
Panels of curtain wall with the same type have different thicknesses
Wed, Jan 4, 2017 at 11:30:35 AM
Curtain wall Panels Pre-delevoped Adding a Door or Window?
Fri, Jan 20, 2012 at 7:55:07 AM
Interior Walls - Wainscot Panels - Revit 2018.2
Mon, Feb 12, 2018 at 4:55:15 PM
How to make a recessed panel in a masonry wall
Fri, Oct 26, 2007 at 7:19:47 AM
Page generation time: 2.3511
