91 Users Online (90 Members):
Forums >> Revit Structure >> Technical Support >> Attaching open web trusses to a sloped beam
I looked on the forums and could not find a solution. I am designing a roof in Revit Arch 2012. I have a beam (B1) at elev 146'-0". I have another beam (B2) that's parallel to B1 30'-0" away. Beam B2 starts on one side at elev 145'-9" and at the other end it is at 145'-4". I am trying to insert an open web 'K' joist between the 2 beams. So I go to my beam truss system to do my boundary and select the 2 beams but I cannot get the joist to attach to the sloped beam (B2). I have no problem having them attach to the top of B1 but I have to manually grab each truss over B2 and pull it down. Any suggestions?
This should be your solution.
I found a couple of posts elsewhere that talk about creating this warp by adjusting the supports. Check this post on AUGI:
http://forums.augi.com/showthread.php?52120-BEAM-SYSTEM-SUPPORTS-!!
Thx WW. Piece of cake after viewing that link
Open Web Joist does not load |
Mon, Feb 20, 2012 at 4:59:59 PM
Structural Trusses not attaching to walls |
Fri, Dec 14, 2007 at 10:54:26 AM
roof framing question |
Wed, Feb 25, 2009 at 11:51:16 AM
Open web truss system |
Tue, Apr 10, 2007 at 9:27:57 AM
Roof trusses |
Tue, Jul 17, 2018 at 1:58:24 PM
Members: | 2017035 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
