59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit Roof Detail Level
Tue, Jun 19, 2012 at 7:44:08 PM | Revit Roof Detail Level
yilin1985
Is there a way for the different material layers in an in place roof by footprint to show up in medium and/or fine detail levels (similar to what happens to walls)?  Is there a settting I need to adjust b/c I can't get the substrates to show up.
Tue, Jun 19, 2012 at 8:16:32 PM | Revit Roof Detail Level
agosztyla
If you cut a section through your roof and hit the same detail level button that you do for the walls it should do the job
Wed, Jun 20, 2012 at 4:06:20 AM | Revit Roof Detail Level
4 Stars: 203 Votes
The issue is "How did you created your In-Place roof"? Only with one "layer" or with several "layers"?
Wed, Jun 20, 2012 at 10:59:56 AM | Revit Roof Detail Level
yilin1985
I modeled it with several layers. @ agosztyla thank you! I realized I was seeing it in elevation not section, so of course the layers wouldn't show up! Doh! >.<
Roof Section Detail
Thu, Mar 3, 2016 at 9:19:26 AM
Wall Detail Level
Mon, Oct 27, 2008 at 2:25:35 PM
Revit toposurface detail level
Fri, Feb 11, 2011 at 3:06:55 PM
Revit Arch 2013 - Roof - Starts at first floor level and second floor level
Mon, Sep 10, 2012 at 8:11:54 AM
Revit Detail Level fill pattern, Texts in Elevation and Section's Symbols
Mon, Jul 30, 2012 at 7:12:55 AM
Page generation time: 2.1061
