69 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Alternate Line Visibility with a checkbox?
Tue, Jun 19, 2012 at 9:17:36 AM | Alternate Line Visibility with a checkbox?
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
I am trying to model a parametric CMU detail family and I've got most things how I want them...the last thing I'm trying to do is create a checkbox to change the face of the CMU block from plain to split face. I know how to apply visibility parameters to an item, but when unchecked it will disappear...how do I make it so that when checked, it shows the split face line, and when unchecked, it just shows a straight line? I'm trying to avoid masking regions since they would mess with the hatch of the block. Many thanks.
Tue, Jun 19, 2012 at 9:25:48 AM | Alternate Line Visibility with a checkbox?
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
Ok, found partial answer on AUGI with the "Not (Y)" command...but...
Is there a way to do this if the line in question defines the boundary of a filled region? For instance, if a checkbox is checked, one line of the boundary is squiqqly (as in a split face CMU block) and if unchecked, it is straight. But in both cases, ideally, the filled region would conform to whichever line is selected.
Tue, Jun 19, 2012 at 10:18:15 AM | Alternate Line Visibility with a checkbox?
3.5 Stars: 395 Votes
Click on the straight line in your family.  Now look at the properties.  At the end of the visible line with the check box is a pulldown.  Se that to your appropriate parameter.
alternate dimensions
Mon, May 24, 2010 at 1:30:15 PM
Using Revit for multi-level alternate
Tue, Apr 29, 2014 at 11:16:33 AM
Alternate Wall system - 2008
Tue, Oct 9, 2007 at 8:50:44 PM
Transparent Solid Filled Line-Based Families
Tue, May 10, 2022 at 8:42:20 AM
Alternate floor plan?
Tue, Aug 21, 2007 at 3:11:29 PM
Page generation time: 0.6071
