76 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Getting Floor thickness in to shared parameter
Tue, Jun 19, 2012 at 5:19:37 AM | Getting Floor thickness in to shared parameter
satheeshbabu
Hi,
Please anyone answer my question.
I need to use Floor thickness as a parameter in beam family editor.
How to get the floor thickness as a shared parameter?
Thanks and Regards,
Satheeshbabu
Tue, Jun 19, 2012 at 7:30:20 AM | Getting Floor thickness in to shared parameter
You may not be able to read this.  I don't use structure but Revit now has some reporting parameters for hosted objects.  I do not know what is available to you in structures so I suggest you search your HELP for "reporting parameter"
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:16 AM
Door Family - wall thickness parameter!!
Thu, May 14, 2009 at 10:19:49 AM
Cannot Locate SHARED PARAMETER FILE!
Tue, Oct 7, 2008 at 3:16:49 PM
Shared Material Between Families
Mon, Aug 31, 2015 at 11:21:41 AM
Referencing a Shared Parameter in a Family parameter formula.
Thu, Jan 29, 2015 at 1:26:25 PM
Page generation time: 1.3569
