63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Wiki Help absolutely worthless
Mon, Jun 18, 2012 at 11:56:46 AM | Wiki Help absolutely worthless
rod23
5 Stars: 4 Votes
Trying to remember something I used to know and can't remember:  How to do 2 different materials in a vertical wall stucture.  Something with split region and assigning layers, can't figure it out, go to wiki only to get run around in circles.  Does anyone know the name of the moron who set up the wiki site???
http://www.turbosquid.com/Search/Artists/Revitaoist
Mon, Jun 18, 2012 at 12:02:38 PM | Wiki Help absolutely worthless
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Go to MODIFY>SPLIT SURFACE then you can PAINT the wall with the material you want.
Mon, Jun 18, 2012 at 12:07:40 PM | Wiki Help absolutely worthless
rod23
5 Stars: 4 Votes
Case in point, went to AUGI and found the answer in 3 minuites:  http://forums.augi.com/showthread.php?111811-Multiple-wall-materials&highlight=vertical+wall+materials
Thanks teafoe, but I was wanting to do it in the vertical wall structure
Mon, Jun 18, 2012 at 12:25:10 PM | Wiki Help absolutely worthless
We don't use the wiki help.  When you install, you also install the built-in help.  It is much better and you can set your pointers to it instead of wiki.
Mon, Jun 18, 2012 at 6:42:15 PM | Wiki Help absolutely worthless
rod23
5 Stars: 4 Votes
Hub, how do I set it to go to the built in help as default when i hit the "?"
Tue, Jun 19, 2012 at 7:25:37 AM | Wiki Help absolutely worthless
To reset the Help pointer, I wrote this for 2011.. 2012 is different and I have not rewritten it yet
In your Revit.ini file set this:
UseHelpServer=0
HelpBrowser=0
You also need to set the locally installed help such as: ENUHelp.cab=C:\Program Files\Autodesk\Revit Architecture 2011\Program\
What file type can Revit write to that will create a non editable 3d image
Wed, Sep 5, 2012 at 2:59:25 PM
Typical Details
Mon, Mar 26, 2012 at 10:53:44 AM
3D Studio Max imported into Revit?
Fri, Jun 29, 2012 at 5:42:25 PM
Revit MEP pipe diameter difference
Thu, Feb 9, 2012 at 11:01:35 AM
Setting up ODBC Export with Open Office Base
Tue, Mar 8, 2011 at 5:32:11 PM
Page generation time: 0.2081
