128 Users Online (126 Members):
Forums >> Revit Systems >> Technical Support >> Twist in Beam
2 Posts No Rating |
I'm new to Revit and just starting to create familys. I have structural element that will drop from the exterior to the interior. This element will also twist in the fact that it will be level at the exterior but will slope at the interior end. The standard revit family functions for the most part as I can rotate the profile to match the slope. However the rotation causes the exterior end to rotate also. I was thinking that I could nest familys in order to add a rotation to the orginal profile to offset the rotaion from the profile. From what I have been reading it appears that this cannot be done. Can anyone help?
Thanks
Can you attach an image of what you are trying to accomplish?
"I have structural element that will drop from the exterior to the interior"
So your beam is sloping from the exterior to the interior
"This element will also twist in the fact that it will be level at the exterior but will slope at the interior end."
Not sure what you mean?
2 Posts No Rating |
The exterior edge should align with the Level and the interior would remain at an angle.
I found a couple of posts elsewhere that talk about creating this warp by adjusting the supports. Check this post on AUGI:
http://forums.augi.com/showthread.php?52120-BEAM-SYSTEM-SUPPORTS-!!
I don't know if that works or not.
Edited on: Mon, Jun 18, 2012 at 11:06:35 AM
Difficult Baluster family to model |
Wed, May 30, 2012 at 9:32:51 AM
Meeting Beam Systems to Glulam Beam |
Wed, Jun 20, 2012 at 10:34:16 AM
Precast Beam System not sitting on beam |
Thu, Jan 10, 2013 at 11:45:48 AM
Steel Beam to Beam Connection |
Fri, Jun 18, 2010 at 1:54:36 PM
Beam & Beam systems |
Tue, Oct 21, 2008 at 4:36:54 PM
Members: | 2057190 | Objects: | 23074 | Forum Posts: | 152250 | Job Listings: | 3 |
