10 Posts No Rating |
hi all....just wanted to ask for some feedback on the following system, which i'm thinking of purchasing:
http://www.ebay.co.uk/itm/251065034079?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
At present i'm running two laptops
one is an amd 64x2 with intergrated nvidia geforce 7000m, 4gb of ram, windows 7 64bit, revit 2010 64bit on dual monitors
second is an intel core i3 with intergrated intel hd graphics, 4gb ram, windows 7 64bit and revit 2010 64bit
both run revit fine or have been doing for some time. However i am now doing more and more rendering work and starting to move onto animation for some clients, which is obviously stretching the power of these laptops a little...
After doing alot of research i know that revit 2010 can use a max of 4 cores when rendering, so i've gone for the fastest i can find within my budget (see link).
With regards to software upgrades, i cannot afford to upgrade revit (£4k is out of my budget right now!), so really its revit 2010 (which has worked fine so far) or i team revit up with artlantis or lumion (although lumion does'nt support 2010 anymore and needs a bit of messing around to import to, but i have a plugin for artlantis and now getting to grips with the interface - trial ver at present). However i have done alot of renders in revit, teamed up with photoshop and have found them great and happy with them...my only major concern is the time it takes to produce the renders. I've played aroudn with settings and can now render a 300dpi scene, without lights, A4 sheet size, with good quality textures in around an 1 to 1.5hrs, depending on the scene complexity. When i include lots of lights, this goes up to around 3-4hrs. I need to cut this right down, so its the main reason why i'm wanting to upgrade. I may have the budget later for artlantis, but at present its merely revit 2010 doing all the work.....
So...basically, do you guys think that this system would increase my render times by around 50-60%?..which is what i am aiming for
edit: also do i need to go for a system with a 1gb graphics card?...i have been looking at systems with intergrated agp (eg ati hd4250) which are nearly a hundred pounds cheaper or more in some cases!...or would this eat into my valuble system ram and cause it to slow down?...
thanks in advance!
![rbcameron2 Avatar](user_avatar/78200.jpg)
![4 Stars: 25 Votes](/images/stars_4.gif) |
Personally I would not get that desktop off your link to ebay. I would buy a computer off ebay, just not that one. Depending on your budget, I'd go higher end on the graphics card, like a Quadro 4000 - 2Gb. 16Gb of 1333Mhz RAM is good enough. The processor is misleading, but anything that gets over 3.0Ghz is necessary. Intel Xeon X5650 (2.66 to 3.06Ghz turbo) is what I would recommend. 64bit of course
ps. GeForce is for gaming, I would be surprised if Revit formally recognized it since it is Direct X type of software.
cheers
rbcameron
thats for the feedback
went ahead with my own spec in the end, since no one seemed to be interested!..lol
for anyone who is, i built the following:
amd 8 core bulldozer overclocked to 4.6 with air cooling, looking to bump up to 5 once water cooler arrives
16gb ddr ram
1tb hdd sata 2
ati 1gb hd card
high performance gaming case with 6 fans
700watt power supply
usb 3
Asrock MB with gigabite lan
windows 7 64bit
revit 2010 64bit
Total cost: £450 .... dam good i reckon
Renderings have gone from 40mins to around 7min (in revit)
artlantis is banging out the same image in around 2mins (300dpi)
Lots of people said to go for the i7, but i just could'nt stretch that far on terms of cost. The amd is a good processor so far and to be honest is my 3rd AMD powered pc.
ONE HAPPY BUNNY.... :O)
